Phazed-Coug
marq said:I can see your point, but it's not overrated when you're trying to obey posted speed limits. I don't want to give the DNR more money than I have to.
Yes but its off in your favor, if it says 55, and your only going 50 you won't get a ticket
87 mph (140 kmh) on dreammeter and 80 mph (129 kmh) on gps!!
SharkAttak
do the speed-o mod, were you grind off one tooth on each side, of the speed-o gear, i believe there's a post on how to do, problem solved
pat the rat
- Mar 13, 2006
Mars
As I reported in another post, if you switch to km/h, it becomes much more accurate.
I guess they wanted the canadians to have "slower" sleds. haha.
simonzsayz
I'm torn. I'm not look'in at my speedo when i'm ripp'in; but if I look at it I whanna know at what i'm Rippin at. I want a speedo! not a dreemsickle or whatever you all call it. I'm glad about the ride comfort, balance, reverse, and the new coolness of the ride but I don't like telling my homies it does 90 if it only does 78. I dont have gps, nitro, viagra or a blowup doll, I got a Phazer! How come the speedo doesn't work? Other than that, And I realy don't care about that, The fazer's the bomb!
Phazed-Coug
simonzsayz said:I'm torn. I'm not look'in at my speedo when i'm ripp'in; but if I look at it I whanna know at what i'm Rippin at. I want a speedo! not a dreemsickle or whatever you all call it. I'm glad about the ride comfort, balance, reverse, and the new coolness of the ride but I don't like telling my homies it does 90 if it only does 78. I dont have gps, nitro, viagra or a blowup doll, I got a Phazer! How come the speedo doesn't work?...
Better trade it in or return it... J/K
pat the rat
- Mar 13, 2006
dont care about the speedo either,as long as im having fun is what counts,gps is for fun too
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
98 mph on speedo @ 12,100 rpm on 1/2-3/4 mile run showed 88.xx mph on GPS. This was on 1-2" of hard crusty snow.
pat the rat
- Mar 13, 2006
tried today on the lake on crusty snow but slides were sticking bad,whats the easiest fix for that
donnyrhodes
- Nov 12, 2006
hot 93 mph today on the lake at 12,000 Rpm
Superman
- Jan 21, 2005
- Gaylord MI
- www.lakeffectsnow.com
Ran mine on seasonal and fire lanes up the U.P. this weekend. but when I did check the Mtn. Lite on the trail I saw no more than about 5-6 Mph difference. 65 mph on the speedo was reading 59-60 on the GPS. Most of the time I checked it down around the 35 Mph mark and then the GPS read 32.
Yellowknife
- Jan 25, 2004
- Yellowknife, NT, Canada
- www.youtube.com
I use km/h and the speedo is out 6% according to several consistant GPS speed tests.
