Be alot of fun trying to do it, you need to at least remove the lower arms so you can get in there and weld in the bottom bracket. Don't think you can weld in the front bracket without removing all the front plastic also. By the time you get to that point your about 10 minutes from having the entire subframe out anyways, and then its much easier to weld and turn to get to all the sides.
