nytro sub frame tourqe specs
rage man
nova scotia
i need the tourqe specs for the 12 bolts that attach the sub frame to the frame of the sled and the stablizer bar mounts to the sub frame allen head bolts thx
Still fresh on my mind where it is in the service manual:
Stablizer bar mounts allens(B): 34Nm with loctite
Front sub-frame to frame bolts(C): 25Nm
thanks dont whant the new one to fall off its actuall not that hard of a job to switch that out is it thanks agian
Mine took 1.5 hours, its not that hard to do. Just take your time and take some pictures of where all the cables and coolant vent lines run before you take off the old one just in case.
How important it the loctite... stupidly I used a copper based loctite which is an antiseize rather than the original blue loctite... a friend didnt use any loctite and didn't tighten to spec.
It only calls for loctite on the Stablizer bar bolts. I don't know how important it is but I do know that from the factory they drench the stabilizer bar bolts in loctite. I had to heat mine to get them out.
