chuckpp
- Mar 27, 2013
- Belmont N.H
- 2016 Yamaha srviper ltx dx
16 ltx dx curves and snowtrackers ,Ok a handling question ,when going through a corner with gas on has a push but once you lift off the gas it turns what would some of the adjustment you guys would make, mostly when 2 or 3 inches of loose stuff on the trails.
tighten front limiter straps or loosen spring to increase ski pressure. mine are all set like yours sounds to be so i adjusted my driving in that i roll off the gas a bit in the corner for ski pressure and roll back on as i come out.
X2 or tap the brake and come out hard. Have to hug the tank and hang out also if really getting into it.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
X2 come in hot and coast through the corner with engine braking and get on it again
SqueezeER
- Jan 16, 2019
- Northern Ontario
- 2020 Winder Ltx LE
Come in hot, get off it, turn, back on er coming out. Drive er like a 4 stroker!
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
If your not standing on the running boards going into the corner then at least lift your but off the seat and over-steer into corner and pin it, get the track coming around, you will feel the rest of it come together. Not sure what you are running for skis and the rest.
