You could start there monitor boost and if boost low turn bolt in a bit at a time. I assume your running a TD or hurricane 20lb tune? If you get lock in to far on max 20 tune you can get into overboost and sled will cut out, this is built into tune.so you mean like 1/8” of an inch from the pivot should be safe for start?
i have max 20 thks bubbyYou could start there monitor boost and if boost low turn bolt in a bit at a time. I assume your running a TD or hurricane 20lb tune? If you get lock in to far on max 20 tune you can get into overboost and sled will cut out, this is built into tune.
