WesG said:Question for the guys that have tested this, DaveF I know you have mentioned this before and I am sure others would know this as well.
At different boost levels say 12, 15, 18, 20, 22 lbs, what pressure is in the header?
Asking because I am searching for a leak using a plumbers plug, but the plug will only hold to about 12lbs before it flies out of the dump pipe. I could build a hose and a cap to bump the pressure up higher, but I am wondering if that is needed?
Wes
