Morgan C89
- Nov 19, 2014
- 2009 Yamaha Nytro
So last night i went to start my sled and it started but the headlight and tail light didnt come on. I had to restart the sled 4 or 5 times before they finally came on. Has anyone else had this problem?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Hid's? If not probably relay
Morgan C89
- Nov 19, 2014
- 2009 Yamaha Nytro
nope just normal headlights
canoehead
- Jan 14, 2011
- NE, Alberta
check your lighting and load control relay
SRX Boy
If is very very cold out, I've had that problem. Once sled warms up 20sec it comes on. Been told that is normal (also happened on an SRX I had) ? Not sure if that is your issue or not
grumpysanta
moisture in light relay common problem change relay for a new red one
NytroJoel
- Jan 16, 2013
- Gaspe Quebec , Canada
- -09 Nytro XTX
-16 Summit X 153
- Gaspésie
+1
Tyloooor
happened to me on Friday night.....after the sled warmed up they came on....it was -25 that night
I would not call this normal. Anyway I would change 3 of the relays to solid state.If is very very cold out, I've had that problem. Once sled warms up 20sec it comes on. Been told that is normal (also happened on an SRX I had) ? Not sure if that is your issue or not
canoehead
- Jan 14, 2011
- NE, Alberta
X2I would not call this normal. Anyway I would change 3 of the relays to solid state.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Just a correction. The headlight relay cannot be replaced with the red solid state relay since it is different. It controls between high and low beam.
It was likely the load control relay, which turns on bothe the headlight and taillight. Replace it with the red solid state relay part number 8GN-81950-00 and be happy. While you're at it, replace the fuel pump relay too. Same type of problem in cold weather.
