heavy hitters
Heavy Hitter
I bought a RXWarrior this spring and wondering if the HH's will be a good investment for the Warrior ? I've read a lot of good comments on them. I'm also wondering if they are easy to install/setup ? Thanks! :p
Hey errol - I have had no experience with Yami clutching before a couple of months ago, and now, I know how to work with the HH setup. Blue By You can set you up with the kit, and if you are just joining us here on the forum, I am doing some testing on asphalt with the HH setup. (you can look under the mod results section, in this RX1 forum). It took me less than 20 minutes to change weights in the primary to the HH setup, And what a difference it made. Timeslips do not lie, and keep checking for updates on the different clutching changes that are being made.
Pretty much any aftermarket weight will be a better setup than stock, which one you choose is up to you!
I could sure use a great setup for the Heavy Hitters for a Mountain sled. I have the weights loaded with what I had heard was best last Fall but if asphalt dragging has found a better setup then I'm all ears. Could you please list your best setup so I can compare it to what I have in the weights now? Thanks Summer sledders. Powder Blue
