Xs825 belt break in
Did you inspect the xs 825 belt before you put it on? There was a bad batch around a year or so ago. I got one. There was a thread on the topic.
Yes looked good. My buddy is running it also no issues. We got them both from hurricane. I came around the point and hit it got half way to nauties and boom. Maybe I held it to long but it was so smooth Sunday evening. I just don’t want it to happen again. Luke said he’ll come over and check and make sure it’s all in spec. Thanks
Here’s some pictures
One more
You need to check and see how much float their is in that secondary. Push the clutch open and down on the belt then check and see how much float there is.
That orange spring doesn't have coil bind. If you were having coil bind, you would have paint worn off between the coils and I am not seeing that. My TP Orange primary spring has the paint worn off on the outside just like yours.
I run mine with less than 1mm float and have zero belt issues running tuned.
Float doesn't always float and when it doesn't it will rip a belt in half from having uneven pull on belt.
That spring is wearing paint off because it’s hitting the spring cup sides. I can assure you the 2 springs I recommended will not look like that in 10k miles. Coil bind may have been the incorrect term but no way a spring should look like that. It’s hitting something clearly and slowing down the shift of the clutch.
Another of the same brand. These marks will not help any clutch set up. I call it like I see it. I will again repeat I like thunder products and use them just not this spring
Is the xs825 the right length for maximum shift out?
From Timken specs:
XS825 = 44-3/8" x 1-13/32"
9200 k on my sled, 9000 k with xs 825, tried a 8dn belt for a 200 k ish ride but went back to the xs belt, 240 tune 24/50 gears with plenty of full throttle pulls, must be lucky but haven’t blown the belt yet.
