We recently did a oil change on my dads 2007 Attak. We put it back together and it runs but here's what's wrong:
There is a yellow check engine light on the dash that is flashing. And the sled will stall if you stab the throttle. It will reve up if you slowly take it there but if you do any sort of throttle stab it it will stall out.
I tried searching but was unable to find an answer.
