snoman
seen oil drip drop under motor and on the right side panel and code 85 been flashing what do i need to check before i check it out and what needs to be done thanks.
shanksyamaha
Sounds like it may be leaking at the tank. I've heard of the tanks cracking and leaking, Id check all around that first...
breakinbarrs
- Dec 31, 2007
- Not North Enough,Ashburnham MA
Code 85 oil pressure switch. Pressure could be low based on leak. I had same issue with my daughters rx1, was the tank leaking. You will find oil in the right side cover and will migrate to the center of bulkhead and drip there.
breakinbarrs
- Dec 31, 2007
