Winder-BTX
- Feb 28, 2019
- Wisconsin
- 2017 Yamaha sidewinder btx
Hello everyone, I have a 2017 Yamaha btx me with 1500 miles on it now and had my oil changed at the beginning of the season and I’ve Checked the oil last trip when we stopped to get food and it was full to the top of the hose. Then when I
Checked after I got back home and it was the same so I let it cool down and started it back up until the temp light went off and it went back down to the max level. Coolent levels stay the same and oil don’t look milky to me. Any input on if that’s normal or what I should do is greatly appreciated.
Pstn head
Overfilled ?
Winder-BTX
- Feb 28, 2019
- Wisconsin
But when I let it cool down and then start it back up it goes right back down to the max level. Would it still be overfilled? Trying to upload pictures but it’s not letting me.
Winder-BTX
- Feb 28, 2019
- Wisconsin
First photo was from today when I stopped to get food and second one is from the other day when I got home and it sat overnight then the last
One is after I started it up until the temp light came on.
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- 2017 Yamaha Sidewinder BTX-LE
- Hewitt, WI
So when the engine is running its at max but then when it's off its full to the top? Just trying to clarify.
Winder-BTX
- Feb 28, 2019
- Wisconsin
So when I got back home today the hose was full then let it cool down and came back like 15-20min later and it was still full but then when I started it it went down to the max level.
I recently asked my dealer about the procedure for checking oil level.
1) Run machine for a few minutes.
2) Let sit for a few minutes then check oil level.
3) Target level when following this procedure is 25% above the lower line.
farmerschiferl
- Dec 28, 2010
- Hewitt,WI 54441
- Hewitt, WI
My thoughts looking at his picture is over full for sure because that would be way over the 25% of the bottom line
Winder-BTX
- Feb 28, 2019
- Wisconsin
Oil wouldn’t look like that if it had coolent in it right? What do you think the foam part on top is?
grubf
- Dec 9, 2008
If it is overfilled it will suck the excess through the intake. Won't hurt anything but you appear to be overfilled. On mine cold is below the low Mark on the tube. Once warmed up it gets above the low Mark a little. Take a little out if it makes you feel better. If you just leave it alone it will get to where it wants to be.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
When the sled is running the oil is circulating and foams up a little. Mine does this also. After sitting for a few minutes it levels out again.
- 8K
