Help with removing injectors.
Joe ltx-le
Beaverbank-ns
Canada
2017 sidewinder ltx-dx
Does anyone have a second to help
Me with removing injectors.
Do I have to remove the airbox and steering column? Or can I skip the rail out under. I thought it would be easier to ask for advice before I start taking it apart.
Thanks for any help.
If you can get at them with the air box on you could leave it on but it probably be easier with it off. Steering is not in the way, just unbolt the fuel rail and unplug the harness and they come out easy.
Great. Thanks
I did the swap no problem.
Administrator can remove this thread if they want.
Curious, why r u pulling injectors?
The reason I changed injectors is because I've upgraded to ulmers pcv and he recommends the bigger injectors. Now I'm ready to run more boost also , atleast ready as far as injectors go.
