rxwhopper
not sure if anyone can help im just curious if there is a ok setup out there to try. i have supertips that were previously in supercharged apex. weigh in at 74 grams. stock my btx doesnt seem to have the jam i thought it would but works ok, i tried a ggb can and it made more power and would over rev. Would anyone have a setup i could use with these supertips and maybe i can put the ggb back on.i plan on ordering a tune next season for this machine but dont want to spend a bunch more on the sled this winter. thanks
- Apr 14, 2003
- Hessel, Michigan
Take a pic of your weight so we can see the way it's setup please. It might work for you right now with the right spring to match.
Also are you stock or do you have tunes installed?
rxwhopper
Just stock. Was debating putting the ggb can back on. When I installed it stock it hit rev limiter all the time makes more power for sure. Some say don’t need programmer for ggb some do. That’s another question. Is it ok to just bolt on the canAlso are you stock or do you have tunes installed?
- 8K
