BryanK410
- Jan 26, 2014
- Newfoundland
- 2009 Apex MTX
Hey,
I got the sled start HID kit from yamaha and when i went through the instructions i found them very vague.
Im pretty sure I can managed but one thing I was wondering is what is the best way to go about taking off the headlight pod to do the install??
Thanks for the help!
There are two 10mm headed bolts on either side of the headlight pod. Remove the bolts and slide the pod forward and off.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
The Yamaha HID kit is made by Sled Start which is company owned by Kurt who is a TY member. Kurt is a great guy and has excellent customer service. If you run into any other questions Kurt will be happy to help you. Kurt's TY username is SLEDSTART if you need to PM him. Kurt is real good about replying to inquiries quickly and taking excellent care of his customers. You are going to love his HID kit. It is literally a "night & day" difference!
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
x2
steiner said:There are two 10mm headed bolts on either side of the headlight pod. Remove the bolts and slide the pod forward and off.
BryanK410
- Jan 26, 2014
- Newfoundland
- 2009 Apex MTX
Thanks guys, gonna go out at it this afternoon.
Any other tips?
Use to be a member of this site years ago but had to create a new account. Good to see this place is still helpful!!
Any other tips?
scott32
- Jan 12, 2009
- huron county, ontario
- 07 Apex RTX se, 09 Nytro XTX
Don't forget the hex screws up top by the ignition switch and 12v plug. I would suggest that if you need help at this stage you may require much more for the install. Post your location an perhaps a nearby member, with experience, can stop by for assistance. Can we assume you have the newest version with the patch cables so there is no direct connection to the battery? If so it truely is plug and play. Your mounting of the ballasts and ziptied cables is then all the problems you will face. Do not touch the bulbs. Cheers
BryanK410
- Jan 26, 2014
- Newfoundland
- 2009 Apex MTX
Just wanted to know how to haul the headlight pod off since nothing in either book on it and never done it before. Garage is full of new kitchen cabinets so had to do it outside in the -20 with windchill, so didnt want no extra fooling around. Again thanks, quick and easy thing to do and I know now after doing it it may sound stupid to ask how to haul the pod off but the way these machines are built you don't know if its 2-4 or a dozen little things holding it in place.
All done now, very easy install and the kit is very good and clean, and looks excellent just again the instructions are very vague, and sections not updated from the previous versions of it from where they use to be wired to the battery such as the section about packing one of the 3-pin bulb sockets that you "dont use" (which you do in this kit) with vaseline.
Engineer so knew I could figure it out but these type of kits for the amount of extra effort it takes should have each and every step 1, 2, 3 and updated from each version. Just a suggestion for the producer of this kit, would only take half an hour to rewrite and proof the entire thing with all the steps and updated for the newer version.
Can't wait to try it out tonight to see the real difference!
apex55
Is there still the high beam issue using these HIDS?
apex55 said:Is there still the high beam issue using these HIDS?
Updated ballasts with the updated patch kit to elimnate the battery connection has no issue with the brights as far as I know.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
hid
I am running the newest version of their HIDS, awesome , 30 min install !They are much brighter than earlier versions and no high beam vibration of the bulbs , Excellent job boys !
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
I just did this upgrade to mine, I hope it is much better than stock I havent tried it yet, but I will let you all know. Install was a snap I had really good directions.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
BryanK410, if you need to adjust your headlight beams, just loosen the two rear screws that hold your key switch panel in place. Pry the panel up a little. This will give you just enough room to stick a long Phillips screw driver in to adjust the beams.
I had to adjust my beams after HID installation.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
You will be shocked. Just spent a week with 7 Apexes and 1 Switchback. 3 Apexes have HIDS the difference is stark. One of the must do upgrades to a Yamaha 4 stroke. I got mine from DDM Tuning, the other 2 are Sled Start.race24x said:I just did this upgrade to mine, I hope it is much better than stock I havent tried it yet, but I will let you all know. Install was a snap I had really good directions.
race24x
- Dec 29, 2003
- Belgrade, Maine
Should I bring a long screw driver for my first ride? Are they that far off after install? I assumed the lights wouldnt need to be adjusted much
Redbeard
- Oct 14, 2011
- IN
race24x said:Should I bring a long screw driver for my first ride? Are they that far off after install? I assumed the lights wouldnt need to be adjusted much
I had to adjust the beams on both my sleds after HID installation, but maybe you won't have to. I didn't have to adjust much. It wouldn't hurt to keep a long Phillips in the truck in case.
