I am a flat land rider but if I was a mountain rider i would install an external out of the hood cold air intake to avoid snow blockage of the intake ect.
hpmaniac
- Feb 21, 2025
- Washington
- 2025 mtx sidewinder
2024 9r turbo
2025 summit xpert 165 turbo r
I ordered venting kit, it has not arrived yet. The intercooler was 100%the fix for my power loss I had.
Kent Smail
- Jan 29, 2020
- Saskatchatoon, Sk, Canadia
- 2014 Summit XMX 800 154
2017 Sidewinder MTX162
Yes, all the mountain guys run them pretty much. I was in snow deep enough on the last trip I was still having issues... had to stop and slap the dong to get the snow off it... But that doesn't happen often its gotta be at least headlight deep for that.I am a flat land rider but if I was a mountain rider i would install an external out of the hood cold air intake to avoid snow blockage of the intake ect.
Kent Smail
- Jan 29, 2020
Like the Mo-flo vent kit for the side panels ? Well that's awesome it cured the high intake temps for you, my last trip out west we dropped into a hole we probably shouldn't have @ 4pm, but it was on the way out haha. I was loosing rpm climbing out of there, intake temps were in the 140 range on the dash, and It was laying soot like a diesel too.I ordered venting kit, it has not arrived yet. The intercooler was 100%the fix for my power loss I had.
I'm still thinking of just going with the straight race intercooler, delete that ice building POS on the nose, I bet there is 20lbs of snow and ice built up there some days
I have the full venting Moflo kit on my SW, since I bought it, for the flatland and can't imagine not having it as it is amazing how much underhood heat these sleds have.
Kent Smail
- Jan 29, 2020
I agree, same kit I'm running as well, I had to reinforce mine with a piece of of aluminum where the secondary is, first time out I cut a hole through the screen and frog skin with the end of the secondary. been awesome sinceI have the full venting Moflo kit on my SW, since I bought it, for the flatland and can't imagine not having it as it is amazing how much underhood heat these sleds have.
So I take it you're really happy with the additional cooler?I ordered venting kit, it has not arrived yet. The intercooler was 100%the fix for my power loss I had.
What numbers are you seeing now?
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
I see a 10-20 degree rise now after a long climb where before i was seeing 40-60 rise. horsepower remains consistent now.
82 mph track speed takes some big power this i know for a fact. Next is a fan which should drop temps even more.
Great stuff. ThxI see a 10-20 degree rise now after a long climb where before i was seeing 40-60 rise. horsepower remains consistent now.
hpmaniac
- Feb 21, 2025
- Washington
2024 9r turbo
Clutching DTAY1 fully loaded with weight, dalton black green primary, 40 degree helix and dalton black tan spring. This combo pulls 8700rpm and 19.6 boost. I switch to a 37/35 helix in deeper heavy snow. Max belt temp has been 140 degrees. Zero belt slip, might step it up to a 44 degree helix.
RDOG907
- Jan 5, 2023
- Alaska
- 2017 Yamaha Sidewinder MTX 162
You could also add the Barn of parts intercooler grill mod that puts frog skin on there so snow more just falls off of it or get a roll of frog skin and put it on the front.
Kent Smail
- Jan 29, 2020
Doesn't help with an aftermarket bumper on it, I've tried 3 different grilles in there over the years. Still the same results. Maybe with the stock bumper loop it might not get hung up as bad.You could also add the Barn of parts intercooler grill mod that puts frog skin on there so snow more just falls off of it or get a roll of frog skin and put it on the front.
This season i cut out some of the bumper so a guy can at least get hands in there and clean out the packed snow and ice.
- 21K
- 7K
