lawmanbsi
Last season I bought my Attak. took it on a four day trip to the U.P. I was getting 11mpg. had several issues that I have taken care of. I was expecting 14mpg but, 11mpg is still what I'm getting. What are some things I can do to help raise this up to 14mpg?
I've been thinking that I need to pass more air through the engine. Modding the intake, exhaust and changing gears.
langow
What have you taken care of so far? Are you studded? What is your current gearing? What weight oil are you running? More questions than answers, but I think we need to know specifics of your current set up to give you good suggestions.
Turk
Tech Advisor
if you want 14 mpg sell the apex & get a vector.
lawmanbsi
Replaced the belt and clutch button. one button was broken and the other two where half worn. Cleaned the clutches. Changed the oil and filter. Used 0-40 mobile one. Replaced all the bogey wheel bearings. Cleaned and greased the jack shaft and drive cog bearings. Replaced hyfax. Repaired skid suspension arms and had Mono shock rebuilt. replaced front shocks. Replaced all suspension bushings. Changed skis from stock with dual runners to Powder Pros with 6" shaper. I have 2 studs per lug. I don't know for sure what gears I'm running now. I assume stock.
lawmanbsi
Turk said:if you want 14 mpg sell the apex & get a vector.
If I can't get the 14mpg or higher I'm going to a different Sled.
langow
Sounds like you've done all the obvious things. If you're using 40W oil now, switching to 20W will help some. With a Power Commander from Ulmer, programmed for best fuel mileage, you could squeeze a bit more out of it. Make sure your chain tension is not too tight, same with track tension. Go on a diet.
All that, Turk probably has the best advice. The Vector gets exceptional gas mileage. Everything is a trade off.
If the horses are in the barn, you've got to feed them!
Turk
Tech Advisor
What 150 hp 120 mph sled gets 14 mpg in real life????
langow
Uumm, I'll get back to you on that one.
Yamaha 40th
Take your thumb off the gas a little more....LOL
lawmanbsi
I have chain tension set to finger tight and the track tension set a half turn tight from racketing.
Diet? that must be the fourth kinda of person
lawmanbsi
Yamaha 40th said:Take your thumb off the gas a little more....LOL
Not going to happen!!
langow
lawmanbsi said:I have chain tension set to finger tight and the track tension set a half turn tight from racketing.
On the chain tension, finger tight, then back off 1/4 turn is best.
I suppose there could be a 4th kind of person. LOL if you can afford to drop 100lbs, your gas mileage will definitely get better afterwards!
lawmanbsi
Really, I'm having trouble with the idea that I corrected the worn out components and didn't get better gas mileage.
- 129K
