How do you carry extra fuel?
Bluebullet
Massena NY
2021 sidewinder LTX GT, 2010 Apex LTX GT
LOCATION
Maine
Guys, I have an 2010 Apex LTX GT and would like to carry a couple gallons of extra fuel on back country trips and was wondering what you guys use?
I bungied corded a 2 gallon gas can on the tunnel extension of my warrior but would like an better option?
I have looked at the stackable type from Kolpin and Rotopacs, They have what appears to be a good mounting system and claim to be secure? Anyone using these?
Blue
I bought a trunk bag and a 4 litre can to carry extra gas on my apex xtx and had no issue with it.
I just got a 3 gallon Rotopac. Went for a week in the mountains and it worked great. 10 seconds to unhook it from the sled. It pours pretty good for a can with no vent. I was impressed with the mount. Can't go wrong in my opinion.
Thanks guys I think I will go with the rotopac or the Koplin. I like the lock down system. I have a rear cooler under my LTX but still appears to be room to mount the lock down. Do you guys have any pics?
Blue
I received the Pac mount yesterday, after doing some looking and measuring it will be a tough fit with my rear cooler. I don't have the gas can yet so I will see when I get that. I was thinking of making a mounting plate, attaching that to the sides of rear tunnel then mounting the Pac mount to it with the can. leaving about an 1/2 to inch gap above the rear tunnel as to not affect rear cooler. just my thoughts? pics anyone of how you mounted yours?
Rotopac makes a mount for sleds. All it does is give you a raised area to put your mount on. Look at there web page. Looks like it would be easy to make if you have, or can find a brake. It is pricy. My rear cooler is not stock so it was not in the way.
Thanks, I saw that mount but thought I wouldn't need it, I may have been wrong! Good reminder!
Blue
Gas storage
Mounted the Koplin pac system yesterday. Only able to use 4 mounting holes( Rear cooler) but seems like the system should be sturdy enough. What do you think? 1 and 1/2 extra gallons will be an improvement. I don't like the fuel light comming on and then guessing if I can make it back! 10 gallon tank is just not enough.
Exhaust ?
Apex55,
I don't think so as the tanks is below the exhaust outlets and 3 inches away? Started sled yesterday and seems o.k standing still, no more next season for sure. I may get the turn outs just in case?
Here is anther pic
I have the same setup on my MTX. I just have a longer tunnel to mount to. I would frequently check to see if the exhaust was warming the tank at all during long runs and the tank was just as cold as the aluminum. I wouldn't worry about the exhaust. It is always nice to have an extra 20 miles of fuel strapped to the back just in case.
Thanks sled neck! extra 20 miles can be a life saver for sure!
Apex55, (Maine)Mostly trails Greenville, Dover, Millinocket, ashland and Spring backcountry North and west of Baxter/Telos area. Just relocated here to Mass last Jan. Where do you ride
Blue
