Glad you got the over-heating figured out. IMO, IF you were overheating that much, there was air in system somehow. The best way I found was to elevate the front end at least 3' more than rear. Raise right-front more than left-front. Loosen the plug on the turbo coolant tank. Run engine and keep that plug loose until coolant is coming out of it. Then, tilt right side down and have left side (thermostat housing) higher than anything else. Run engine and keep topping it off until it's full. Key is to have front of sled about 3-4' higher than back. I used my engine hoist and a sling to lift front up high. I have never seen high temps and never gone into limp even on hard icy trails. But, I do have scratchers and if trail is icy, I put them down.
