eskimopauk79
Starting have this problem, takes 2 to 3 cranks to start, I always had it pump first for every key turn, any solutions for this starting issue?
eskimopauk79
Change plugs, Tried fuel injector cleaners, with no success
sprintcat
First start 8 out of 10 times , it seems to be warm blooded.
RIGIDONE
Mine takes 2-3 turns of the key for a first start of the day no matter if its 30* or -10*F. I also turn the key on and let the fuel pump cycle before trying to start it..I dont really find it to be an issue, my other ones do the same thing..
musselman
- Apr 17, 2009
- Fenelon Falls, Ontario
- 2019 Ren XRS 900T, 2010 Nytro RTX
Above -20 one try, -20 to -30 usually takes 2 to 3 tries, -40 no start, will not crank.
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
one turn down to -15celsius(5,0 fahrenheit) and 2-3 turns if its colder than that.(starts and cuts)
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Guys stop talking about turn of keys. You should all know buy now you keep on the starter until it starts period. This is not a starter with a bendix like cars. Starter has a planetary gear. No harm if you leave it on and less chances for fowling. You can even break it of for some reason your engine backfires right after cranking like is happening on the Vipers.
04nightfire
-35C it took one time to fire. The next day at -25C it took two times. Figure that's not bad for the original 3 year old battery and stock relay
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Mine fired in two tries at -25F. I think I was colder then the sled was. haha
ken0la
Mine used to always start on 2nd turn, always wait til pump is done fogg'n, this year after changing plugs, 3 turns...
