blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Got enough snow to play around on and my sled currently has 400 miles on it. I have the Big Venom clutch kit installed and it goes right to 8600rpm range with the Gates Carbon 8jp and stays there past 90mph. I'm tapping the limiter on launch a touch but I really haven't found a good place with a firm base yet to test launch rpm. I'm thinking about leaving the weights alone if they will pickup another 200-300rpm in the next 1000 miles. I know my Phazer kept "loosening up" until ~1500 miles. Bringing up the "Max RPM" shows me hitting ~9325 when I tap the limiter off the line so I'm pretty sure I don't have the original 14' flash, what do the 15-16 and 17' flashes have for Max rpm?
Mine gets faster every year and I am right at 10000 mi!
Leave it ride,ride,ride!
New flashes are higher rev limit
alexm2816
- Mar 28, 2016
- SE Wisconsin
- 2016 SR Viper LTX-DX Turbo
I came here to type the same question LOL. I am thinking about playing with the weights... but i'll wait till I get another 1000 miles on
allyammies
How high? Just went and did the new flash 2 weeks ago. Ill have to wait till xmas week to see.New flashes are higher rev limit
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
i agree mine seems to pull harder every year..6000miles currently
Was told it’s now up to 9300rpm. I have not checked myself. Previous was up 50rpm from original 9200.How high? Just went and did the new flash 2 weeks ago. Ill have to wait till xmas week to see.
allyammies
Ok good deal. I should just run up there tomorrow and try it.
If you mean the new flash just be warned it may take two tries to start your sled after. Other than that the flash is a good thing meant to prevent kickback and starter failure. I got flash last season and have not had a issue other than I am a bit lean in cruising range now. Go for it.Ok good deal. I should just run up there tomorrow and try it.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Sounds like your getting decent speed already, mine started to loosen up between 700-900 miles, but like others are saying it keeps getting better and better every year as the miles pile onGot enough snow to play around on and my sled currently has 400 miles on it. I have the Big Venom clutch kit installed and it goes right to 8600rpm range with the Gates Carbon 8jp and stays there past 90mph. I'm tapping the limiter on launch a touch but I really haven't found a good place with a firm base yet to test launch rpm. I'm thinking about leaving the weights alone if they will pickup another 200-300rpm in the next 1000 miles. I know my Phazer kept "loosening up" until ~1500 miles. Bringing up the "Max RPM" shows me hitting ~9325 when I tap the limiter off the line so I'm pretty sure I don't have the original 14' flash, what do the 15-16 and 17' flashes have for Max rpm?
