I have been doing the 20lbs lately.
bot
- Aug 17, 2016
- ottawa
- 2014 viper long track
Question on track align... took sled to dealer hr drive...had them do a recall on it and service it and put 4th recall on it... now home in the shop notice one side.. i can get my thumb between track clip and slider...the other side..can t even get my pinky finger...looks like track clip is almost rubbing slidder...dont have a tool for putting 20lbs on it and measureing 2" sag once i try to fix it ..gotta fix it by tomoro nite..going riding fri morn... right now its tight on ur fingers ,with two fingers in there so i can go by that..but whats best and easyist way to get it to move to the throttle side a bit.so its not so close to track clips
bot
- Aug 17, 2016
- ottawa
Tighten brake side or loosen throttle side. Track adjusters. rear of skid. they move the rear wheels.Question on track align... took sled to dealer hr drive...had them do a recall on it and service it and put 4th recall on it... now home in the shop notice one side.. i can get my thumb between track clip and slider...the other side..can t even get my pinky finger...looks like track clip is almost rubbing slidder...dont have a tool for putting 20lbs on it and measureing 2" sag once i try to fix it ..gotta fix it by tomoro nite..going riding fri morn... right now its tight on ur fingers ,with two fingers in there so i can go by that..but whats best and easyist way to get it to move to the throttle side a bit.so its not so close to track clips
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Less then a 1/4 turn at a time!Tighten brake side or loosen throttle side. Track adjusters. rear of skid. they move the rear wheels.
Track does float from left to right though
Especially whe you turn and stop to park it will be tighter on the outside edge
ltxbill
- Oct 10, 2017
- onalaska
- 2015 yamaha sr viper ltx se 1998 srx 600
I had the same problem after putting 4th wheel kit on. I had to leave one of the bolts on the wheel tight, then adjust the other side to get it centered.
bot
- Aug 17, 2016
- ottawa
And if u want it to go to throttle side tighton brake side?
YesAnd if u want it to go to throttle side tighton brake side?
Hawwwtcoffee
- Oct 9, 2016
- SR Viper
- Muskoka
- www.supertraxmag.com/nats
When your tracks at proper adjustment in respect to tightness use a tape and measure the threads on the adjustment bolts or if you got time and a finger nail count threads. Your axle should be square to the rails.
Carla 123
- Feb 27, 2017
- Manitoba
- 2015 viper xtx boosted
17 zr9000 precision stage 3
Mines is a little close than that but it sure is a pain,could not or my dealer get it centred perfectly ,I'm just riding it .And the wheel kit does nt look like the track is centerd on it
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
Be sure to check the upper boggies for alignment.....if your fully clipped you will chew the wheel up FAST if its not set right..there is so little space i just set my track via the top wheels
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Man you guys are anal! Just make the track sag even on both sides and call it good. About 3/4” where the sag is the greatest, with no weight your done.
Measuring the threads is useless and can be totally off.
X2Man you guys are anal! Just make the track sag even on both sides and call it good. About 3/4” where the sag is the greatest, with no weight your done.
