BluCru
- Nov 23, 2016
- Indiana
- Yamaha Attak
My track will not align correctly so i was wondering if there is an easy trick to get both sides equal from track to wheel.
Hoxtongue
- Jan 23, 2014
- 2006 Yamaha Apex RTX
Possible you have something bent, rail?
Loosen nut off the rear shaft, take long socket and turn 3 to 4 half turns on one side only and see if it gets worse. If yes then back them back off and tighten the other side making sure you still have the correct track tension
Loosen the rear axle. Hang the sled from the rear bumper so the track does not touch the floor. Check the sag of the track. If not close adjust it equally with the track adjuster nuts (14mm) thru the track windows.
Loosen the adjuster 1 turn on the side where the track edge is closer to the wheel and tighten the other side where the edge is further away from the wheel. Fire the sled up and spin the track. Check year gaps. Do this until they are even.
Tighten the axle nut when done.
Indy
How close does it have to be? within a 1/4"?
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
It does not have to be perfectly even. The whole idea is to have that little bit of space between your slider(hyfax) and the upright on your track clips when you stop on a FLAT surface and check it. The space will be generally be between 1/8 and 3/16 of an inch on each side.
