How To Replace Top Gear In Chain Case?
mtuyamaha
Age
29
Houghton, Michigan
2007 Yamaha Phazer MTX 151
81' enticer 300 twin special
75' Scorpion 440 Whip
I'm planning on changing my top gear on my mtx back to a 17t (previous owner put in a gt top gear) but Im at college right now and want to have all my eggs in place before I get back home for Christmas. Any help and Pictures would be greatly appreciated!!
Remove battery, remove 4 bolts to swing the battery box out of the way, remove brake calipers rotor, and remove the side cover. If it has a 20t GT gear you will probably need to remove the lower gear also to get the chain off, I just barely got the chain off a 19t when I just switched to an 18t. 17t ran out of clutch too fast at my ~1800ft altitude on my MTX, 66mph GPS /73 speedo. 19t would go 74gps/82 speedo before it was out of clutch (and took a long run on hard pack. Trying and 18t this winter.
So my sled is an 07, I've read somewhere that there is a chaincase leak that can occur if the chaincase is opened. Is this true?
Never heard of any issue other than the tube going to reverse box. There is a update for that. Different tube. May want to do that while in there but it has nothing to do with taking chaincase cover off.
I do have to rock my sled back and forth to get the R and D to engage and I heard that was a common problem for the 07. My sled does have 8800 miles on it too though.
the 09 i just bought with similar milage is the same way.
