How to tell if my bars are updated?
jaydaniels
Bedford NS Canada
Canada
2017 Sidewinder RTX
Well, just got myself an Apex. Finally decided to try one after riding an SRX for the last 6 years. So far I love the sled. Fit and finish etc is awesome. I have been reading that there are issues with he hand warmers especially the 06's. I also read that many updated the 06 bars to 07 bars. How can I tell if my sled is updated to the 07 bars? I also read that if you have 06 bars, putting the 07 updated wiring harness will help with the heating issues.
The 07 and newer are one bar with bends on the end. On the 06 bars the bent ends are inserts. I have the 07 harness and 06 bars and have hot hands. There many posts on this if you search.
handle bars
the bars that came on the 06 sleds have a hook on the end that is not heated(separate from the rubber heated grip)the 07 and up bars have the rubber all one piece out to the end of the hook and heated to the end.
i just put the updated bars on my sled and also installed ROCKS WARM HAND CONTROLLER and they now work great. they heat up before the sled is warmed up.
hope this helps
ANDREW
Thanks for the replies, looks like I still have the 06 bars. How does one go about finding the 07 harness update?
06 Attak with 07 bars and Yamaha fabric hand guards with velcro and couldnt be happier.drf
06 bars
you say your bars are 06 i would keep them if i were you if they are pluged into the up dated harness they will fry your hands the up date kit does not work any beter than the original but if you are intrested in the 07 bars heated to end of hooks i have a set i took of a new 07 even trade i am back and fourth from pei all the time wiil be gone for two weeks 902 672 2755
Thanks, I'll keep that in mind. How does one go about updateing the harness. I've been searching around but can't seem to find anything on this. Can you get the harness update without having to purchase the bars?
KEEP your 06 bars and either get the Yamaheater or 07 harness. I got the Yamahaheater and your hands are extremely WARM with this update.
The 06 bar hooks are not heated but, honestly do you need them to be?
Great sled too!! The engine is awsome!!! ;)!
Anyone know the part number for the harness?
Harness
Got this number from another post a while ago supposed to be $11.00.
Phazer sublead p/n 90891-50150.
sub lead
jaydaniels said:
So this will work on an Apex even though it says Phazer?
The post I got the p/n from said it works for the 06 Apex bars, same sub lead that came with the "updated" 07 bar kit for the 06.
Well, checked with dealer and they say you can't buy just the harness. You need to buy the kit. Also had them run the about part number and it they have no idea what it is. Oh well, I'll worry about it in the fall I guess.
