Looking for a little help from you guys to save some time. I'm going to be installing my kit this weekend and was looking for advice on setting my clutch up after the install of the turbo kit. I'm sure there are others out there with the same setup that have already tuned their clutch. I have the following:
2014 XTX
Hurricane 190 Kit
Ulmer primary machined for overdrive
Ulmer secondary setup for 8DN, Ulmer red spring and clutch kit
Hindle exhaust
Studded track
Stock head pipe
Thanks in advance for your help!
2014 XTX
Hurricane 190 Kit
Hindle exhaust
Studded track
Stock head pipe
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
2014 XTX
Hurricane 190 Kit
Hindle exhaust
Studded track
Stock head pipe
You will love the Hurricane 190 kit, runs awesome. I run the hurricane clutching, primary cut for overdrive with stock belt. If you already have an Ulmer setup you might want to give him a call but chances are you will need all new components. At the very least you will need a secondary spring and helix and more weight on the primary arms.
I think Ulmers helix that I have will still be okay but I'm sure I will need to change the weights.....just hoping someone has already done some testing on the same setup and can chime in.
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
You might be able to get it to run the correct RPM with the current helix but you won't be getting all the potential out of that 190 hp.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You have 50 gram base weights, here's a starting point for you.
Primary Spring: Stock (Blue-Silver-Blue)
Heel: 4 washers per side
Mid: Empty
Tip: 4 washers per side
Red Spring set @ 3-3
K helix
Mid: Empty
K helix
Dealerjohn
- Mar 26, 2010
- Labrador
- 2015 MTX Viper, XTX Viper, 2001 SRX 700
Doesn't the Hurricane kits come with clutching now?
Thanks Allen!You have 50 gram base weights, here's a starting point for you.
Mid: Empty
K helix
You can get it with or without.Doesn't the Hurricane kits come with clutching now?
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
Yes they are included for no extra charge now. I think they started doing that at the beginning of the summerDoesn't the Hurricane kits come with clutching now?
Sent from my iPhone
Dealerjohn
- Mar 26, 2010
- Labrador
Sent from my iPhone
That's what I thought. Probably a good idea to talk to the man who created this kit. I'd say he has a good idea how to properly get the power to the ground. I'm planning on going with the Hurricane kit as well, I hope it works out for you.
