baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
Maybe loose battery cables or i think some sleds last year had a connector loose and wouldn't charge battery, not sure witch one but was in nose of sled if i remember correctly, hour meter shows boost on dash when started on new tunes not voltageI started a friend's srx and noticed the volt gauge fluctuating at idle. Thought it was odd.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I never looked I'll check mine out next time I ride!! I am sure it normalI started a friend's srx and noticed the volt gauge fluctuating at idle. Thought it was odd.
geez150
My 240 stock muffler flash required a 3 bar sensor..?Correct me if I am wrong, but doesn't the 240SS tune require a 3 bar, where the 240SM tune does not?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
my 240 sm flash only added daltons and a BOV .My 240 stock muffler flash required a 3 bar sensor..?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
The ss sm tune all run 3 bar
I beleive first gen of sm tunes were 2 bar and 3bar was developed a little later
When I first got my sm tune bundle early last season it used the stock map sensor later in season I add the 3 bar sm tunes to mine!!
You can still get the sm tune with stock map sensor or the tunes that requires 3 bar
Still lots of guys running the stock sensor on the pm tunes(240 270 290)
Sledbrapping88
- Oct 6, 2019
- Upstate NY
- Yamaha sidewinder ltx
Hey mark I'm running hurricane ss sm tune bundle with dtay 1 with 78.5 grams with blk/org secondary spring wrapped 6-3 I switch over to the xs 825 belt from 8dn do you think dtay1 will be too heavy for the xs 825 belt or should just empty the weight and send it
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Try removing all the slugs and put 1 3/8 slug in each with ultimax.Hey mark I'm running hurricane ss sm tune bundle with dtay 1 with 78.5 grams with blk/org secondary spring wrapped 6-3 I switch over to the xs 825 belt from 8dn do you think dtay1 will be too heavy for the xs 825 belt or should just empty the weight and send it
Sledbrapping88
- Oct 6, 2019
- Upstate NY
Ok sounds good if remember correctly your suppose to bottom out the slugs then back out just but.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I ve never done that!!I always bottom them outOk sounds good if remember correctly your suppose to bottom out the slugs then back out just but.
Sledbrapping88
- Oct 6, 2019
- Upstate NY
Really I was told at dave shop to do this I guess it doesn't matter
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I
I have to Call Dave monday and I'll bring this up and get back to you
Maybe with multiple slugs so they lock in? With just the one slug I would rather it tight that way there is no chance of it moving.Really I was told at dave shop to do this I guess it doesn't matter
Sledbrapping88
- Oct 6, 2019
- Upstate NY
I
Ok sounds good
geez150
I always thought that you could move the slug to the pin or tip depending on where you needed the weight?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
You can, just make sure if the thread locker is worn off the threads you install some locktite.I always thought that you could move the slug to the pin or tip depending on where you needed the weight?
