saskattakman
x2^^
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
This is all the info available.its ment just to show the delivered hp gains to the track.further feedback will be given shortly as guys receive there arms by the weekend
HURRICANE
- Oct 17, 2007
- Prescott Ont.
klutch kits are now in stock ready to ship
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
So dave you are 100% safe to run your hindle muffler and clutch weights w/out a tune and no fuel problems? Do you guys plan on making a tune for the SW this year? If a tune is in the making will you have different stages of HP tunes,like stage 1 220 hp stage 2 250 hp tune at varying boost settings? And will you guys be flashing them in NY or only Canada?klutch kits are now in stock ready to ship
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
BTW guys we sell the Hurricane Hindle muffler now thanks to Dave. It makes power and runs great on our TD ecotrail reflash. Just tested today at -20 celcius !
Can it run without flash?
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
It seems to make power so my first impressions is it will be a little lean for cold days.Can it run without flash?
However Hurricane does say they can be run without a tune. He's done some testing on them.
I've only tested on our ecotrail map and it works well for that application. That's all I can say for the moment.
We will performing a lot more testing this weekend, with stock muffler (ecotrail for stock muffler), new TD cold air intake and new 3" race pipe.
If we have a chance we'll try some of the muffler options for stock tune, namely our TD stock modified stage 2 muffler and the Hurricane Hindle muffler as well.
woodzynh
- Sep 11, 2012
- Nashua, NH
- 2015 Yamaha Viper XTX LE
Would be interested in keeping it stock tune, aftermarket exhaust and clutch kit.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I like seeing you guys work together! It's like a big Walton family Christmas. If you can sell tunes to his muffler, hey all the power( and $) to you. Have you TD guys slept at all this month? I'm getting tired just reading all your posts...keep it upIt seems to make power so my first impressions is it will be a little lean for cold days.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
We were out testing the hurricane sidewinder muffler on the trails with a boost and afr guage set installed. This exhaust and our supertuner clutch arms is a sweet combination.the boost was never over 10lbs and the afr was 12.1-1 at wot. Thats the same afr that we saw on the dyno with stock tune.this set up is absolutely prooven safe
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
Hopefully my arms arrive over the next day - I'll be running this setup (with Hurricane Hindle) over the weekend. I'll be putting it to the test against a local MCX Apex...should be fun.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Where r u running?Hopefully my arms arrive over the next day - I'll be running this setup (with Hurricane Hindle) over the weekend. I'll be putting it to the test against a local MCX Apex...should be fun.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
Where r u running?
Possibly Whitewater or in your neck of the woods.
How about you?
DMCTurbo
- Nov 12, 2005
My place is right on the trail close to Whitson so that's where I'll be heading. I'm told there are tracks on it but I'm going to auger it tonight just to be sure.
DMCTurbo
- Nov 12, 2005
How will -20 or colder temps affect it?We were out testing the hurricane sidewinder muffler on the trails with a boost and afr guage set installed. This exhaust and our supertuner clutch arms is a sweet combination.the boost was never over 10lbs and the afr was 12.1-1 at wot. Thats the same afr that we saw on the dyno with stock tune.this set up is absolutely prooven safe
