yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
sorry I meant whitewaterAll good boys.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- - 2017 Sidewinder XTX SE
- 2016 SR Viper LTX DX
- 1997 Mach Z
Yup - Whitewater this AM
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Do you also have huricanes clutch ramps set up for his muffler from hurricane?I did. And Nelson Lake Rd. Beautiful snow conditions back there.
Re: Hurricane Hindle...all I can say is, the thing sounds amazing. First ride with it today. The skis didn't spend a lot of time on the snow...the sled screams.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
Yup
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I see you installed hex bolts, wise choice.I did. And Nelson Lake Rd. Beautiful snow conditions back there.
75northface
- Oct 26, 2016
- Sudbury, Ontario
- 1997 Mach Z
Also applied copper anti-seize for good measure...fingers crossed.
Silkysmooth3popper
- Mar 19, 2013
Just got my Hurricane muffler. Came with 6 new hex bolts. Now I don't have to go find some. Very impressed.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
racecar
Suspended
- Dec 22, 2016
- Zr9000
Nice exhaust. Have a couple of questions before I make a desicion to buy.
1. There is no flex pipe like Oem and like all other aftermarket manufacturers? what happens if the tip of exhaust hits something? What gives? Will the flange crack from vibration. I see that TD has a flex pipe.
2. The flange on the turbo has a flat section over the waste gate. Will that hurt performance. I see in the turbo industry they have a different pipe for the waste gate or divorced type. I thought the theory was to have a separate stream to limit turbulence on the main exhaust.
3. With this muffler will I be safe on stock programming at -25 wide open throttle. I do a lot of riding in northern Quebec.
Thanks.
A lot of stupid question for first post.
Die hard v max 4 guy
Thanks.
HURRICANE
- Oct 17, 2007
- Prescott Ont.
We did not add a flex joint because there is no movement in the turbo therefore in the exhaust.the science developed in the hurricane exhaust is in the flange at the turbo. We created this design to control the boost so therefore the afr at factory settings where stock mapping is used.as the boost is raised from reflashing,the efficiency of the flange increases accordingly. This is why we gained 16hp without the need for reflash.the engine runs at stock boost and afr for safe operation.
racecar
Suspended
- Dec 22, 2016
- Zr9000
I am not sure, but if I go over a snow bank and my exhaust tip hits it will it bend?We did not add a flex joint because there is no movement in the turbo therefore in the exhaust.the science developed in the hurricane exhaust is in the flange at the turbo. We created this design to control the boost so therefore the afr at factory settings where stock mapping is used.as the boost is raised from reflashing,the efficiency of the flange increases accordingly. This is why we gained 16hp without the need for reflash.the engine runs at stock boost and afr for safe operation.
If it is more difficult for the waste gate to expel over boost wouldn't that be the case with the flat flange and increase boost?. Sorry for all the questions. many posts on other sites discussing this. I am not sure what I read is true. No dis respect.
So at minus 25 I have no lean condition for sure. TD and others have posted that a flash is needed. I just don't want to be in the middle of no where in northern Quebec and lean out and loose a motor.
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
no more updates?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
Mufflers are working good
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Dave, I know this post is old but dragging it out again. Reading through all of this it says you have a clutch kit setup for a stock tune and the muffler using the SuperTip weights. Do you offer one with the Dalton weights like a QAY-70 arm? I like the Dalton weights being adjustments can be made from the machine.
How often are they needing a repack?
thanks!
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
thanks!
I'm sure Dave will check in but in the meantime, FYI his kit was Hindle with his own SUPER TUNER weights not Supertips.
I ran it last year no issues.
Worked very well.
I raced 2 Stock Winders on lousy snow 660'. I beat them both several times by 4 lengths or more in 660' and my sled only had 100 km on it.
It is not quiet but better than an Apex drone.
- 39K
