ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Just an FYI for you guys running the Hurricane intercoolers. The bar the intercooler lays on beats the backside of intercooler up pretty bad and I have spots that are worn substantially. I couldn’t get the pic of the intercooler to download but you can see the bar is worn pretty good. For now I have the bar wrapped with rubber splicing tape but next off season I will weld a mounting point to the bottom of the intercooler to hold it from hitting the bar. Also my coolant tank almost rubbed a hole through as you can see.
Not sure of my fix for this yet.
While you have the intercooler off it’s probably a good idea to replace the factory hose clamps on the silicone boots with clamps designed for turbo applications (Bolt & strap type clamps). The factory clamps are pretty chinsee and not designed for boosted applications.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Man......that could make for a bad day!
Nice find, Steve!
Nice find, Steve!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Some other issues I’ve found are on the exhaust side. The aluminum oil pipe that runs behind the muffler rubs hard on the mounting shaft for the muffler. It wore through the rubber splicing tape in one year so I had to give the pipe a small bend to alleviate. Then I also noticed my oil temps were trough the roof @ 300 degrees on a warm day. Well that’s not hard to figure out with an exhaust pipe 1/2” away from my oil tank. I wrapped the exhaust pipe and muffler so we will see if that helps, I’m sure it will.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Well no more rubbing on the intercooler since wrapping the cross bar with rubber splicing tape but I did have the throttle body boots pop off the motor. Crazy I know, the intercooler has no mounting points, it held in place buy the boots only. In rough trails this can cause the intercooler to bounce. This eventually caused the entire throttle body and intercooler to pop off the motor. My remedy for now is strap the intercooler down with wire ties until I can fab up a mount to the frame.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I also had to cut the corner off the intercooler and re-weld a piece. It had almost rubbed a hole through the coolant tank.
- 12K
- 16K
A
