titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
I was holding it for roughly 20-30 seconds just figured it would pull to at least close to 100 not fall on it's face around 85
And I'm not sure how the seconds this done, hurricane turbo clutch kit is installed by the dealer before I picked it up
Just curious if you have your sled running good now? Sounds like you had some real problems at this point...
- Dec 4, 2014
- 2015 RTX LE- Hurricane Turbo
Ok so I was taking with Dave got a new primary clutch spring and a set of guages , sled is running awsome, it's a beast, couldn't ask for anything more, my send him the clutches for machining - don't know what too speed is now tho, rained on the weeken and snows just about gone, need more snow then well see if anything has changed - it revs higher tho, just not sure exactly to what was more interested in seeing what psi I was at. Running at 5 psi right now ,
titanrcr
- Jan 3, 2011
2015 Viper LTX SE
2011 Apex
Glad to hear it's running well for you. Let us know how the top end speed is when you get back out on the snow!
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
What primary spring did you get?
leizearmx
- Nov 2, 2014
- 2014 viper rtx
2007 phazer
I have a 2014 Blue/White RTX with hurricane 190 kit and clutching. I can not get mine over 90 MPH and is hitting rev limiter pretty bad. Any ideas? Should I try a new belt first? Thanks!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Pm hellflyer(member here) he has his set up wellI have a 2014 Blue/White RTX with hurricane 190 kit and clutching. I can not get mine over 90 MPH and is hitting rev limiter pretty bad. Any ideas? Should I try a new belt first? Thanks!
leizearmx
- Nov 2, 2014
- 2014 viper rtx
2007 phazer
OK Thank you. I will give him a shout.Pm hellflyer(member here) he has his set up well
- Dec 4, 2014
Ya so way late reply but I had it running good with the 1 3/4 track, it would do 90 mph on just about anything and about 100 mph on hard pack/ ice conditions. I lost all last winter due to a dealer problem (dealer fucked me over on warrntee a committed insurance fraud) (learned my lesson too don't switch sled switch sleds with a buddy - mine ended up in a tree) a but I got it back and am now running a 1.5 ripsaw track and regeared it 21/41 and she'll do 100 mph easy Havnt a had the greatest conditions to get a finial top. Speed yet... I know in the - 30 C temps we've been having it over revvd a tad but around - 10 or so it was revvng rright around 9100.
leizearmx
- Nov 2, 2014
- 2014 viper rtx
2007 phazer
OK so I put a new belt on and broke it in. I am still bouncing off the rev limiter so I checked my max rpm and it is at 9300. Is this OK or what should I do? I am pretty mechanically inclined, I just don't know much about clutches. What else should I check or adjust? Thanks!
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
When are you bouncing off rev limiter? Full throttle at 100mph or on take off. It sounds like you need more tip weight. What weights are in your clutch kit. My hurricane kit has no tip weight and runs 8600-8800
leizearmx
- Nov 2, 2014
- 2014 viper rtx
2007 phazer
I hit the limiter any time I run WOT. From the start, cruising at any speed, long pulls. Anytime I mash the throttle it bounces off the limiter many times until I let off. I honestly don't know what I have on it as I installed the kit and never messed with it because like I said I don't know much about clutches so I did not want to just start messing with things.When are you bouncing off rev limiter? Full throttle at 100mph or on take off. It sounds like you need more tip weight. What weights are in your clutch kit. My hurricane kit has no tip weight and runs 8600-8800
hellflyer
- Dec 2, 2008
hellflyer
- Dec 2, 2008
And are you using the stock primary spring?
leizearmx
- Nov 2, 2014
- 2014 viper rtx
2007 phazer
yes they did and yes stock primary spring.And are you using the stock primary spring?
hellflyer
- Dec 2, 2008
That's strange! Did you make sure your clutches were good and clean with no binding when it was apart! Mine has one large tungsten washer/weigh in the heel of each weight from hurricane. I've since added a bit more but only for the hole shot
