NB-NYTRO
It sounded find when I went to buy it. I got it home and it sounds like a bad rattle coming from the back of exhaust. Is it the exhaust donuts?
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
Could be...get the copper ones.
Grimm
If they're rattling and loose enough, you should be able to see the clamps turning by looking into the tunnel holes.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Look down the tunnel at the bulkhead. With a light you can see the exhaust donuts through the holes. If the exhaust clamps are rattling because of bad donuts you can normally see them spin on the pipes while the engine is running. If they are bad spend the extra money for copper donuts from Sled Toyz.
NB-NYTRO
Thanks guys. I will have to get it in the shop and see what's going on. I want to get it fixed up and move it out.
