PattyJack
Alright, so about a year ago I posted telling you guys my story of how I had a spill on my phazer, where I hit a piece of re-bar sticking out of some concrete. I buckled up my right top a-arm and my right spindle plus two or three bolts throughout. So since then I've purchased the parts I needed for that whole deal.
In the process I went head first into my gauge pod, giving it quite a smack, causing the display to go blank for about an hour. It eventually came back to life and seemed to function perfect. The problem is, it is now flashing error codes 1 & 2. I have searched the wiring for quite some time and have found a small worn spot on one of the wires. It is a small black braided line that comes from the throttle side down where a rubber sleeve is covering the connections. I could get a picture if it would help any. I'm just wondering about what some opinions on what it may be. I hope it is simple because I am a high school student, with a limited budget (part time job) so I really hope the gauge pod is working correctly. Its functions seem to be fine.
Also, in the process of disassembling the sled I by mistake pulled the throttle body from the engine. Should I not fool with this because of the fuel lines and throttle cable and so on, and get a technician to look at it or should i be fine disconnecting everything so I can re-clamp it on.
Sorry for the long winded rant, but I am trying to learn as I go, so I am able to fix my own sled. Thanks guys!
spike337
That's how you learn. Take lots of notes, and lots of pictures. One step at a time. You'll get it.
yam177
PattyJack said:Alright, so about a year ago I posted telling you guys my story of how I had a spill on my phazer, where I hit a piece of re-bar sticking out of some concrete. I buckled up my right top a-arm and my right spindle plus two or three bolts throughout. So since then I've purchased the parts I needed for that whole deal.
Nothing scary about id, Disconnect the plugs and put it back in. If you look last year I posted some pics about engein replacement should have some details about it in there I think
PattyJack
Alright thanks, I'll take a look! Yeah, I'm trying to find out what these codes are. I'm starting with trying to find a short in the electrical system. Then I'll test the plugs for a disconnection. Then if all that fails, its a malfunction in the gauge pod
MikeWalters
Don't forget to check the warp coils and the phase modulation of the plasma conduits.
Sorry man i just had to do that! lol
PattyJack
Haha, I'm only just realizing the complexity of that post. Its funny when I speak to my ski doo friends about what I am doing with my sled, and they just say " man , I just have a needle that goes up and down.. :S" Sounds like something out of star trek haha.
Ruckus
You might want to re-modulate the phaze coils as well...or modify the plasma injectors...worked for me.
RIGIDONE
u guys are mean,,,,lol..but it is funny
PattyJack
karl
- Dec 9, 2007
- Whitehorse, Yukon Territory
- 2015 Phazer XTX
take some of that limited budget and buy a shop manual - best thing for your education in maintaining your sled
PattyJack
Any specific ones you recommended, or are they all quite similar. Ebay has almost a hundred of them so I'm not sure what to pick.
karl
- Dec 9, 2007
- 2015 Phazer XTX
I bought the Yamaha manual from the dealer for the specific year of my sled. It is worth every penny.
RayKnobs
don't buy one, you can download the 2007 Phazer manual
karl
- Dec 9, 2007
- 2015 Phazer XTX
RayKnobs said:don't buy one, you can download the 2007 Phazer manual
^^ what he said... best solution. where is the downlaod available?
Right here.upper left just right click and do a "Save As" its a PDF file.Will work on posting a newer manual also but most everything is covered in two there.
http://cannondalecentral.com/
