RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
Ok so I'm going to start installing my innovate lc2 air fuel and my innovate Mtx boost gauges. Can someone with the install experience give me the quick skinny on best spots for power and ground. Accessory 12v plug for power? I can run the map sensor hose to the leftover blow off valve port on the mpi kit? Best place to mount map sensor? Thanks guys!
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Mpi recommends the extra port on the three way . I believe that's what your talking about.
But to be different I put it right on the throttle body. Theres a nipple on each throttle body with a rubber cap. To me it seemed like the best place after the throttle plate.
I had zero luck with my innovate psb1. It fogg d up instantly and The afr part stopped working. Innovate told me when I called that I should not have the o2 sensor after the turbo becaus there is too much terbulance there for the sensor.
I'm pretty sure you'll have better luck with those gauges. They are more resistant to moisture.
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
I've ran innovate mtxs this short winter on my hurricane kit. Nothing bad to say about them. Always turn on and super easy to read. Here's my setup and I just wired them to the 12v plug and put the quick connecters next to the factory hood connector so everything is right there when I take the hood off.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- Comstock Park
Anyone have an LC-2? Mine is just blinking... Don't know what to do. I can data log it live and its reading but not displaying. Just blinks 7.4 all the time.
