powderpimp1
Just installed a set of Ohlens front shocks. after i torqed all the bolts i noticed a large amount of play on the upper shock mounts. is this play normal?
Indy
Mine don't have any.
snugmat
I just put a set on mine also. The stock shocks had a washer on either side of the inside mount. I could not use the washers as the new olins were wider than the stocks. so i just mounted them without the washers. Fit right in there perfect , no shake to speak of. Mine have the remote resevior and are on an 05 shorty. If you have a lot of side play you could go the washer route like my stockies were.
powderpimp1
the shake isnt the shock on the bracket but the shock on the spacer.
snugmat
Mine are very tight. You need a pair of pliers to turn them. Something does'nt sound right.
Indy
I am not sure of this, but I think I might have used the OEM spacer on the Ohlins.
p0wd3rp1l0t
powder-can u take a pic of the shock and post it? that would help us otu a lot or try and find a picture of a shock and try to explain to us what the problem is.
powderpimp1
I dont know how2 post pix but heres a URL. ist the top fitting on the left image.p0wd3rp1l0t said:powder-can u take a pic of the shock and post it? that would help us otu a lot or try and find a picture of a shock and try to explain to us what the problem is.
http://www.hardracing.com/SNOW%20WATER% ... sFront.jpg
snugmat
So the bushing must just fall out ? If that is so you are going to have to contact whomever you bought them from and work things out. I got mine from pioneer performance and there was nothing loose at all. In fact if you wanted to remove that bushing you would need a hammer and a punch. Same shocks as your picture.
irondog rtx
shock eye play
pimp I am a ohlin dealer where did you get them and is rare that some thing is wrong but anything can happen. check with your dealer or did you buy them used or privite sale somethings up would like to help but never had this from the factory go wrong keep us posted all new ohlins fit most front ends but there a slight diff in how high the front end sits . The only one I cannot get fronts for are mountain apexs good luck kim
Indy
just change the tube that the bolt goes thru, use the OEM.
powderpimp1
I got them at the Novi sno show from Port Yamaha.
RX-1st Place
definatley not normal, i would call ohlins www.ohlins.com they are the most knowledgeable on their own stuff.
