installing Oillite Bushings
markowinnipeg
New Bothwell, Mb
Just waiting for new bushings to show up and got the plastics off but cannot figure out how to get the inside A-Arm nuts off?
Does this require the entire bulkhead to be removed? I cannot even get my had in to the nuts so no idea how to get a wrench or socket in.
Any help is appreciated, thanks
If I remember correctly, the lower arms have nuts at the rear of the arm, the top arms are bolted through the sub frame, it is threaded so there are no nuts on it.
You need to remove the bumper then the nose and side plastic to get to the nuts.
yes thanks all I think to hot in the garage to think, had a cold beer and got her all figured out.
Top nuts are welded to frame lowers are loose.
The top stock bushing were very thin, damn plastic. Thanks again for the help
Just remember, "RED" Loctite is your friend!
