mtotguy
- Jan 20, 2011
- Montague, Michigan
- 2016 Rush 800, 2014 Viper RTX, 1983 Excel 3
I just picked up a rear skid plate. I notice it came with fasteners. Does this mount to existing holes or will I be drilling new holes? Looks like I'm going to want to cut out an opening to drain oil on the right side.
wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
You will be drilling holes in new locations as well as using some of the existing holes.
Some good pictures here of them installed by yamahaguys,
http://www.ty4stroke.com/threads/xt...dded-added-skid-plate-on-the-le.130309/page-3
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
The yamahaguys stopped by my place Sunday afternoon for a little thirst quencher. Based on my experience last year and theirs on their 2015's I would recommend that you start the install at the front of the sled and work back. In addition you may have to drill out some rivets but I believe the only modifications you should have to make is to slot a hole or two in the skid plate to make it fit to the existing holes.
Good luck and enjoy!
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
There is a few rivets you need to drill out and some new holes you need to drill in the plastic also. Once you hold it up under the sled it will all makes sense. Install the screws toward the front loosely to hold it in place and start drilling the holes using the skid plate as a template. Our first on took a few hours and the second on took like 20mins. A extra set of hands will help and a few beers to.
Nytros rule
- Jan 30, 2011
- Rider Nation
- 2014 Black Viper XTX
Drill 1/4 in holes in the bottom/back of all your ribs to let water drain, other wise water collects freezes and wants to push the skid plate off.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
Great point, mine go into a heated garage after most rides so I've not encountered the issue. Thanks for sharing!
yamahaguy
Ride SAFE
- Apr 20, 2014
We drilled them when we put ours on with 1/16th bit. I also drill the skis so they drain also , i hate seeing a puddle of water standing in the skis.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
We driled them when we put ours on with 1/16th bit. I also do that to the skis so they drain also.
If you've seen pictures of your new Vipers after a ride you probably need holes drilled around the whole sled for drainage! LOL! It looked like you were driving submarines when you took those pictures last night! Looking like you had a great ride!
