birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
I'm in Norway. Is it good??
Birkebeiner
Birkebeiner
birkebeiner
- Jul 27, 2009
- Norway
- Norway
J&T 4 wheel-kit. But I install the 8 inch wheels.
And are you running the Hygear linkage kit? What do you think?
Birkebeiner
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
The shocks are new for the winter. I haven't tried them yet
Janne339
- Oct 31, 2015
- Sweden
- Sweden
Birkebeiner
Mostly I running trail so I think the hygear linkage is great.
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
I've got a xtx, I got my tri hub out but for the life of me I can't get enough slack in the track to get the new kit on. I've got the park brake on with a ratchet strap to pull the slack but it's still not enough.
Vilas
- Sep 6, 2014
- Urbana, Illinois
- 2014 Viper xtx, Thunder products clutch kit
Did you loosen the tension adjuster nuts all the way? The next step I suppose would be to remove the bolts that hold the chassis to the upper track wheels. That will leave you with lots of slack but it is a bit of a pain.I've got a xtx, I got my tri hub out but for the life of me I can't get enough slack in the track to get the new kit on. I've got the park brake on with a ratchet strap to pull the slack but it's still not enough.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
I have xtx and it's easy to pull the skid. That's how I did it. Why fight the track.
Vilas
- Sep 6, 2014
- Urbana, Illinois
Also, after you loosen the tensioning bolts take a wooden mallet or something and give a couple whaps on the back of the track to slide the axel forward. I think I did this if I remember correctly.I've got a xtx, I got my tri hub out but for the life of me I can't get enough slack in the track to get the new kit on. I've got the park brake on with a ratchet strap to pull the slack but it's still not enough.
trevorl1
- Mar 14, 2015
- Nova Scotia
Got it in after a bit of wrestling, now I have another issue.
The track is too tight even with the adjusters backed off the whole way.
I have the front of the skid in the lower hhole and the rear in the middle. If I drop the rear to the bottom hole will is give me a little slack?
Edit: I just finished my wife's ltx in about 20 mins start to finish, plenty of slack in the track to work with.
trevorl1
- Mar 14, 2015
- Nova Scotia
Anyone?
birkebeiner
- Jul 27, 2009
- Norway
- Norway
I just ordered the J&T big wheel stealth kit with 4th wheel, I'll know in a week or two
Birkebeiner
Birkebeiner
What holes is your skid mounted in?Anyone?
trevorl1
- Mar 14, 2015
- Nova Scotia
It was upper in the front and middle in the rear.
I switched the front one to the lower hole to give more clearance for my header.
Might be the problem. 14's were in top holes front and back.
trevorl1
- Mar 14, 2015
- Nova Scotia
I just put the front skid back in the upper bolt and plenty of slack now.
