birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
I see. So better safe than sorry, I guess?
What's the verdict on 2 (or 3) wheels inside rails vs 4 wheels? I don't understand why they come stock with just two wheels inside the rails if the argument is that it should side hill better and then add two idler wheels outside the rails at the front of the rails..??
That's a good point! I never felt a handling difference with the added wheels but some claim they do.I see. So better safe than sorry, I guess?
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Any other tri-hub replacement kits out there?
Birkebeiner
Birkebeiner
- Apr 14, 2003
- Hessel, Michigan
I know of 3
J&T ATV
Belanger Racing
Larson
J&T makes a great kit (In fact I just placed another order with Todd Friday) J&T also is an advertisor here
J&T ATV
Belanger Racing
Larson
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Got many thousands of miles on J&T kits, since 2004.
I know of 3
J&T ATV
Belanger Racing
Larson
And Turbo Dynamics. It is just like J&T but not powder coated
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
I just, finally, got my 16 XTX and the first thing I put on was a Larson Racing 4th wheel kit. I really have to say that I was over impressed with the quality, precision and fit of this kit. It truly is way over built. After putting it on my sled with a buddy, he ordered one to replace his factory 4th wheel kit. It is really amazing how flimsy the tri hub is once you get it out.
Hillbilly2015
- Oct 22, 2014
- 2015 Yamaha SRviper STX DX
I'm having a hard time deciding on the jt 4the wheel kit or just the tri hub replacement. Can i replace the tri hub with the suspension in or do I have to take it out? 2015 viper stx dx. I have 5300km on it so i want to change it before it fails
InRBigness
- Apr 10, 2014
I just did mine in place with the track still on. It was really not that hard and only took about 1/2 hour. Mine was brand new with no miles on it so that may have affected the time.
Hillbilly2015
- Oct 22, 2014
Big wheel kit or just the tri hub replacment?
InRBigness
- Apr 10, 2014
I put in the Larson racing 4th wheel kit. You remove the tri hub and install the two inside wheels on the axle put the axle in the track between the frame rails the. Install the outside spacers and in stall the outer wheels. Put on track adjusters, adjust track and tighten up outside bolts on outside wheels.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
I like the Turbo Dynamics wheels
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
birkebeiner
- Jul 27, 2009
- Norway
- Norway
J&T 4 wheel-kit. But I install the 8 inch wheels.
What rear shock are you running??
Birkebeiner
Janne339
- Oct 31, 2015
- Sweden
- Sweden
I live in Sweden. The rear shocks are from Engans Racing in Sweden
this HTML class. Value is http://www.engans.se
