TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
http://s1129.photobucket.com/user/rsvec ... 4.jpg.html
Jack shaft socket tool
1.Buy a 36mm socket from local tool shop $10.00
2. Cut the tool just behind 36mm head
3. Weld the two parts together with 2 inch black iron pipe, I used 6 inch $5.00
4. Use torque wrench to remove and install
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Great work TOMBOB, I added the pic to Your post.
rxrider
TY Management Team
rxrider
TY Management Team
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
jack shaft bearing removal tool
rxrider'
I also made a jackshaft bearing tool similar to the one you made. made out of 3/8 rod with notch in it
so you can side under bearing and above jackshaft. used with the old side hammer, but same old problem
getting the collar out. my collar came loose end of our last ride so it came out easily. I tired your method
but it did not work for me
I have read lot of your posts and with out a doubt one of most talented guys on this site
tombob
rxrider'
tombob
helmic
- Nov 10, 2008
- Bathurst N.B. CANADA
- 2014 Apex SE STUDED,PC5,D&D Performance Exhaust,MAX-REV intakes,D&D BullsEyes,Ulmer clutch kit.Yurbo coming soon!!!
tool
X2 X2
X2 X2
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
Thanks for the kind Words
Sometimes it gets really stuck....
- 38K
