Nasty1
- Feb 15, 2018
- Enfield
- 2017 137 LTX-LE Sidewinder
2007 Apex GT
- CT
I'm the new owner of SteveO 's sidewinder that chewed grapes in the chaincase.
In the process of gathering parts to put humdy back together, figured I'd rip out the new PEER bearings that came in the new chaincase.
Could someone post a higher quality bearing that should be in there.
Both bearings, Jackshaft and drive shaft numbers.
Thanks.
Thanks.
Turboflash
- Mar 18, 2019
- Southern MN
Chain case side:
Stay away from bearings made in China, India, Malaysia, Vietnam, etc.
- Upper bearing in chain case is 6206 open (no seals. This bearing has a seal behind it just like bottom bearing. Oil from chain case lubricates it).
- Lower bearing is 6009 open. Again, it has a seal behind.
- Jackshaft bearing is 6206-2RS C3.
- Track shaft bearing is 6009-2RS C3.
Nasty1
- Feb 15, 2018
- Enfield
2007 Apex GT
- CT
Thank you !!! this should be in the sticky !
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
The jack shaft bearing behind the secondary is a Koyo specialty bearing made just for Yamaha I believe, if you get the 6206-2RS C3 from a job shop or similar, the ID @30mm will be too large, so unfortunately you will need to order from dealer/Yam.
Has to do with the ID of the Secondary clutch being an oddball size approx 28.2mm.
Being a Koyo bearing I decided to clean and repack with grease and will do so yearly similar to the Apex.
Cheers
Cheers
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I agree with @Nasty1 ... add this to the FAQ section.Chain case side:
Clutch side:
Buy Japanese or German ball bearings such as NSK, Koyo, Nachi. SKF, FAG, Timken.
DMCTurbo
- Nov 12, 2005
Thanks for this.Chain case side:
Clutch side:
Turboflash
- Mar 18, 2019
- Southern MN
Koyo is fine. Made in Japan.
Must be Yamaha Sidewinder has a different bearing behind secondary than Cat? If so, I made a bad assumption. The bearing numbers I gave are for Cat chassis. Sorry.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
This is my old sled & an old friend, Crazy Mike.
Well at least he "looks" older then me.
The irony of this whole thing is he traded in his POO that this same sled towed to get the nickname Tow Mater.
WARNING: Please rebuild correctly cuz the 600 will not TOW!
P.S: The saying is "Frozen Grapes in a Blender"
P.S2: It's HUMPTY........................damn Newbie's
Nasty1
- Feb 15, 2018
- Enfield
2007 Apex GT
- CT
Update::
Just measured the Bearing ID on the Drive clutch side of Jackshaft the ID 28mm
The Bearing ID on the chain case side is 30mm
These are measurements off my old 2017 Jackshaft.
Awaiting the new jackshaft to arrive, if the sizes are different from listed above I'll post an update.
Turboflash
- Mar 18, 2019
- Southern MN
Yes, chain case side is a 6206 open. 30mm ID x 62mm OD x 16mm width. Winders have a special bearing behind the secondary clutch. Cat has a standard 6206-2RS there.
DMCTurbo
- Nov 12, 2005
Is this bearing only available through yamaha? Hopefully not as they are on backorder until mid February.Yes, chain case side is a 6206 open. 30mm ID x 62mm OD x 16mm width. Winders have a special bearing behind the secondary clutch. Cat has a standard 6206-2RS there.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yes only Yamaha and yes on back order . At least that I could find. Stupid why they would do that.
What isn't on backorder from Yamaha? I bought a 2021 GP 1800R SVHO Waverunner and ordered parts for it before even taking delivery. Everything on backorder!
DMCTurbo
- Nov 12, 2005
I found one at a dealer down south thankfully and they are shipping it up to me.
RAMSOMAIR
Whew
