Mr.Winder
- Sep 25, 2017
- Mantorville
- 2017 Yamaha Sidewinder
I have a 14 viper I'm trying to remove the jackshaft to replace the bearings in the chaincase and clutch side. I have all the clips taken off both sides. There was no clip on the clutch side. I tried to move the threaded collar in to release the jackshaft but it will not budge. Is there something I'm doing wrong?
You loosened the nut and gave it a few taps with a punch and hammer?
Mr.Winder
- Sep 25, 2017
- Mantorville
Yes and it still did not loosen upYou loosened the nut and gave it a few taps with a punch and hammer?
Do you have the bolts out of the support on clutch side?
Mr.Winder
- Sep 25, 2017
- Mantorville
No I do not. Do they need to be out?Do you have the bolts out of the support on clutch side?
It may be necessary. Here is a guy that had this same issue. Its not going to be fun but it was accomplished without ruining anything except the bearing in case.No I do not. Do they need to be out?
https://ty4stroke.com/threads/jack-shaft-removal-need-help.144621/
Mr.Winder
- Sep 25, 2017
- Mantorville
I will give it a shot. Thank you for the helpIt may be necessary. Here is a guy that had this same issue. Its not going to be fun but it was accomplished without ruining anything except the bearing in case.
Sorry its been a bugger. Feel for ya. Just think about riding. Will be worth it!
