jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
How do you remove the jackshaft from a Nytro. I have the chaincase cover and all the gears and internals off as well as the secondary clutch. I see a small retaining clip on the jackshaft on the clutch side. Do you remove this and then slide the shaft out the chaincase side? I'm looking to change the upper bearing in the chaincase. Thaks.
