rtx moose
- Jul 31, 2014
- WATERTOWN,MN
anyone put a TEAM FAST King air suspension in a sidewinder?I guess it blows away all others..since Karpik is working with yamaha now maybe they will buy them out and Yamaha would be on top?
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
my brother in law has a king an all i can say is it is awesome what a ride. G Karpik was laid off 1 year ago because of covid 19
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
If yamaha could get Karpik to join yamaha they would be the suspension leader
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Really what’s wrong with suspension in you sled?? How’s that one better? Explain curious why! Mine rides plush stock.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Karpik is no longer employed by Yamaha and if this suspension was as good as some of you think a manufacturers would have bought the patent. Nobody has and one of the draw back's is all the top end it scrubs off, nothing wrong with the rear skid in the Winder when set up properly.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
There's nothing wrong with mine at all,I also have the helo suspension add on and it's awesomeReally what’s wrong with suspension in you sled?? How’s that one better? Explain curious why! Mine rides plush stock.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
karpik just put in a patent with yamaha couple weeks ago..how long ago did he leave?Karpik is no longer employed by Yamaha and if this suspension was as good as some of you think a manufacturers would have bought the patent. Nobody has and one of the draw back's is all the top end it scrubs off, nothing wrong with the rear skid in the Winder when set up properly.
TPAY243
- Apr 14, 2013
- Northern Wis
Not sure where is this patent with Yamaha you speak off.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
TPAY243
- Apr 14, 2013
- Northern Wis
Look at the filed date 2019
franklin
I have my 2021 in newberry mi for another week we are going home on Saturday. It has a king air, air assault shocks, and a gse power steering unit just like t bgg e on yamaha bought so they can put it on the 2022
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
It has to do with the bypass shocks more than the suspension itself. If I could add a bypass for first 1/2-2/3 of stroke of procross it might help a ton, but they run a larger diameter shock and piston so it can be more sensitive to bumps. It gives cushy through the smaller low speed stuff and just takes a beating in the big stuff apparently.
- 14K
- 8K
