Couple updates:
1. Cold start was brutal, I was adding too much fuel, took some away and it fired up
2. IAT reads 11,000+ degrees when its froze and needs to heat up. I can't find any comps for this so i think I am safe in the motec tune
3. Boost still uncontrollable, takes longer to get to 20 psi but still gets there and hits my cut. So I will have to add a 2nd Wasteagate
4. Lowered SC boost is not as fun, I will want to swap back to 10-11psi for trail snap that I like. It was better then a turbo alone but still had a tiny amount of lag.
5. I need to muffle the WG dump.
6. Closed loop fuel the sled does not like .89 as a aim value, I will take out 4% and go to .85 pretty much everywhere except full boost.
Lambda works on and off and seen a slight correlation to really rich lower rpm in vacuum and .67 flashed a few times before it would just show 1.000 for about 10 mins after that. I may be washing the sensor. I have a new one to try. Wish I could load test it this summer and really dial in the fuel tables in a controlled condition then just comp for lower air temps in winter
Lastly my 11 yr old daughter came on her first trip and had only put 5 miles on the ski doo we fixed up last summer, My dad came out of snowmobile retirement to ride with her on the 07 600 Ski Doo SDI with a 2 up seat, she rode behind him for 50 miles and then they swapped and she drove for 30 miles! She did great and the smile was ear to ear. Next year we will get her the WI permit so she can drive herself and she is already counting the days until we can do so! She is hooked! A chip off the old block with this quote "Dad I like seeing the hills so I can push the gas and get a little air"
