bot
- Aug 17, 2016
- ottawa
- 2014 viper long track
Does anyone have a l.e.d barr hooked up to front bumper on there viper......i seen a lad near bancroft with one hooked upto his artic cat... he said it made a world of diffrence and he had it hooked up to run with his high beams.... i d like to do this for my gf's 2014 viper with a 6" single row l.e.d barr from black dimond xtreme.... my question is..... how hard is it to feed the wires back to to batt under seat...and how do u go about hooking it to ur highbeams..?... is it a big job , do u gotta tare the sled apart? ...thanks for any info on this!
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
I have two 4" cubes on my skins bumper and works really good. It's pretty easy to run all the wires to the battery and I hooked the trigger for the relay to the high beams. You will have to take all of the panels, hood and the seat off to run the wires. Here's my setup. And this is the plug I tapped into for the high beams. The plug is right next to the reverse beeper.
bot
- Aug 17, 2016
- ottawa
Do you have to remove the head like and cowel ..thxs a million
Dirtbikekid1998
- Mar 3, 2013
- Maine
I had to remove the whole hood assembly but I never took the headlight off of the hood assembly.Do you have to remove the head like and cowel ..thxs a million
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I just installed a 7" Tri-row 9000lm under my front bumper. Haven't got a chance to try it out yet.
bot
- Aug 17, 2016
- ottawa
Did u have to tear sled apart.. like head lite and the dash console...or just side panels and hood..thnks
r.anderson
DirtBikeKid what headlight bulbs are you running? Look much brighter than stock
Dirtbikekid1998
- Mar 3, 2013
- Maine
Rocztoyz HIDs they are awesome!! Plug and play.
http://www.yamaheater.com/YTJ.php
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
any pics!!I just installed a 7" Tri-row 9000lm under my front bumper. Haven't got a chance to try it out yet.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Just be careful going too bright! I have a pair of 30* "flood" degree 18 watts (~2500lm) on my front bumper and it casts quite a bit of light up close which actually hinders distance vision since your pupils close up. I tried a set of 15* "narrow" ones too and those still cast a lot of light in the near field, so much so that I just went back to the 30* for more filler light in off trail conditions. I angled each pair so the had a slight overlap, covering 60*x 30* and 30*x 15*. Another note, the BRACKETS will crack on the Ebay specials, right were the bracket bolts to your bumper if you don't install a large HD washer under the bolt head.
tapex_07
- Feb 15, 2009
bot
- Aug 17, 2016
- ottawa
What lite bar is that tapapex..what lite bars do u guys recomend..
bot
- Aug 17, 2016
- ottawa
Sorry tapex
tapex_07
- Feb 15, 2009
Its just an ebay special. $50ish for two lights. 7" tri row.
Sr Viper X-TX 141
What headlights are you running. I want to replace my halogens. Also, what is the brand for the two led cubes on the bumper?I have two 4" cubes on my skins bumper and works really good. It's pretty easy to run all the wires to the battery and I hooked the trigger for the relay to the high beams. You will have to take all of the panels, hood and the seat off to run the wires. Here's my setup. And this is the plug I tapped into for the high beams. The plug is right next to the reverse beeper.
