04mx
went for a ride today -20 sled ran fine for most of the ride then all of a sudden when I wanted to accelerate it felt like it hit the limiter so I let off , tried to go at it again same thing tried again and it let off a backfire ???
Now I have a code 26 .
Could this have caused the code
Pstn head
Well... code 26 is upstream pressure sensor. Maybe try drying up that area real good and see if it helps.
04mx
Yes I will try to heat them up with a hair dryer . Up stream is a little vague tho !
@123
do you have a aftermarket exhaust without a tune? it happened to a couple of guys around here in cold weather .Yes I will try to heat them up with a hair dryer . Up stream is a little vague tho !
errol
Hi 04MX,
Got the exact same problem as you yesterday riding at -22C
Back firing and sled running sluggish at high rpm!
Stop the engine for 5 minutes and the code went away and the sled was fine after that!
Anybody with more ideas about this problem?
04mx
No everything is stock !do you have a aftermarket exhaust without a tune? it happened to a couple of guys around here in cold weather .
@123
91 octane fuel?No everything is stock !
04mx
04mx
Yes 9191 octane fuel?
04mx
Update ... called the dealer and he said to remove and clean the electric valve with the hose going to the air box also to remove the hose from the valve to the air box and cap off the nipple on the air box and just remove the other end of the hose from the electric valve .
I put 3volts to the electric valve while blowing air in it and liquid came out !
Now sled runs fine now !
geez150
So snow/water must have got into the air box and down that hose?
Doug Heald
- Jan 2, 2019
- Maine
- 2017 LTX SE Yamaha Sidewinder
Had code 26 flashing today, called dealer and he said remove hoses and blow out lines, I did all 4 sensors and all hoses underneath those sensors and the code still flashes, dealer says run it and the code should go away! I have it sitting in my heated garage tonight will check tomorrow , I did the roll over valve mod, and block of line going to turbo and the back of air box, not sure what else to do but run it, if anyone has ideas I am all ears, thanks Doug,
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Code 26 is loose hose clamps/ boost leak??? Pretty sure I had this and that’s what it was
Doug Heald
- Jan 2, 2019
- Maine
Went thru water hole and water splashed up on hood and windshield, code came on 20 mins later, had some water into CAI, blew out all hose no backfire, will run tomorrow hope it goes away, won't do any harm!
