rear2high
I checked my straps and one looked OK and the other one is soft and mushy wear the upper bolt goes through it. They are still in there stock hole. Was wondering if there is to much pull on them or are they just made out of shitty material? Going to put cat ones on and lenghthen them to maybe get a little more weight off the skis. Sled has only 1250 miles.
SKIDOZER
DO you still have the front shock (rear) spring all the way tight?
may be from the shitty rear shock with no rebound damping
rear2high
Yes I do have the spring set to the highest setting. I think to that when a better shock is put in the rear then that front shock could be backed off some. Ive have noticed on here that others have broken the straps on the pro-active and was curious what may be the real cause.
garserio
- Nov 30, 2004
- Fairport, NY
- 2014 SR Viper
2001 AC Z370
2006 AC F120
I broke my straps on a big bump. When I first setup the sled, I readjusted them from the factory setting and I think I might have tightened the bolts too much. If the washer digs into the strap, then you setup a failure location. Be sure to lightly tighten and put the filleted side of the washer against the rubber. (All stamped steel has a filleted side and a sharper side from the shearing action)
That's my 2 cents...
