fourload
Powertrail, XS 825 belt, stock weights up front, 35/39 dalton with orange TP secondary spring @ 40. Runs great very smooth engagement with very clean clutches. Rpms @8800. After running over 500 miles in Canada last week I would like a little more backshift in the 30-70mph area. Should I increase my wrap 10 degrees or should I go back to the stock 35 helix? Don’t want to kill my efficiency too much.
Fleecer
- Jun 13, 2014
- 2019 SRX
Are weights 19/20 or 17/18?
fourload
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
If you had adjustable weights you lighten the heel. Wrapping more will help but it may hurt you clutching temps.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I would try the 35 helix, don’t know, if you don’t try. What primary spring are you running?
fourload
TP orange 30/135 . Engagement is nice low 26-2700.I would try the 35 helix, don’t know, if you don’t try. What primary spring are you running?
Fleecer
- Jun 13, 2014
- 2019 SRX
Those two springs are stiff on the end, which work well with the 39. The only room I see for improvement would be to go to set of Dalton weights. Imo this would require changing out both springs and helix to get it right. You seem to be in the ballpark.....so I'm not sure the juice will be worth the squeeze. Lol...just my opinion however, so good luck!!
Given that you are using the stock weight rivet set up from 17-18, try taking a gram or two off the end rivet or switch it to the aluminum.
I did just put an ecotrail tune in a new 19, and just left the clutching alone. The sled shifts just under 9
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Blue-silver-blue primary spring and stock 35 helix, TP orange same wrap might be an option to try.
fourload
Yes I have that primary spring. My old Nytro spring. I will change it out and the helix tonight. Will let you know when I ride it tomorrow.Blue-silver-blue primary spring and stock 35 helix, TP orange same wrap might be an option to try.
fourload
Changed up my clutching. Backshift is much improved in the 30-70 mph range. Rpms are about 8900. Much more responsive all around. Couldn’t get a top end but it rockets to 90 instantly. Thanks Clutchmaster.
