ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
https://www.ultimaxbelts.com/cms_files/original/Ultimax_XS_Belt_Dimensions_3_29__17_.pdf
This is coming from their site, but that doesn’t mean it’s current.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Normally from 8jp to 8dn i need +1mm washer in tha stack... It used to be same thing for XS belt. (825 to 805)
Now their specs have change.
805 is 44,7/8 OD and the 825 is 44,5/8.
805 is +2mm wider,+ 1mm thicker than xs825 it was not like that before.
Do you have any documentation or is this what you have measured?
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
This is what i have measured. Post #114 an #149Do you have any documentation or is this what you have measured?
Turboflash
- Mar 18, 2019
- Southern MN
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
LooolXs805
Xs825
[QUOTE
="Turboflash, post: 1521355, member: 32347"]According to Timken official chart they sent me on 2-5-2020:
XS805 is 1-3/8" x 45-1/8". 1.375" wide
XS825 is 1-13/32 x 44-3/8". 1.406" wide
XS825 is .031" wider than XS805.
XS805 is .75" longer than XS825[/QUOTE]
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Wow that’s crazy far off!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I have 2 new xs825’s at home I’ll check them out Sunday
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Why do these belts look different? I got the new one from Dennis Kirk (February 2020) and the old one from Amazon (Carlisle as the seller). Purchased two from Carlisle on Amazon in December 2019.
One looks different because it’s blown the fu€k up!
The old Carlisle belt is different lettering.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
https://www.ultimaxbelts.com/cms_files/original/11127_Ultimax_TechTips_CVTBeltDimensions_0730181.pdf
I’m not so sure I buy this load of BS, I think a difference of 2mm is huge and incorrect as Byam stated. If your measurement is supposed to be at the cords how the hell can an 8dn belt be a 1/2” shorter on the outside diameter? it would technically be even shorter if measured at the cords!
It’s just an excuse to maintain $hit tolerances.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Hi snowcaineWhy do these belts look different? I got the new one from Dennis Kirk (February 2020) and the old one from Amazon (Carlisle as the seller). Purchased two from Carlisle on Amazon in December 2019.
You can clearly see the fabrication date on them!
The broken one is made week#20 of 2019
The New "old one" week 46 or 48 of year 2018
mainedrummer
- Apr 13, 2019
- Up North
- Yamaha Sidewinder
At the end of the day, does it seem ridiculous to anyone else that with 200+ HP in these machines, we don't have better things to be concerned about than +/- 1 mm in a belt's width or length?
Perhaps even with hi-end ($$$) aftermarket clutches, if everyone is still so concerned about this, maybe a CVT system isn't the right answer for the sled's powertrain...
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The reason Byam is concerned is he machined a primary clutch for more O.D. and pulled the 825 down into the secondary hub and blew the belt. So he needs a longer belt to keep it from going to far in the secondary and blowing. The 805 should have been quite a bit longer than what he is measuring.
Run an 8DN...
